recording to DVD (tried various formats and brands) to Panasonic DMR-EZ28 ... mostly it works great, except when I try to record from our local FOX HD channel (Channel 25 in Boston) - then the audio is intermittently distorted (clipping or out of phase or some combination) ... but it only seems to happen on this one channel. Any ideas or suggestions for debugging ?
Are you tuning from on-air antenna or cable? Analog NTSC, ATSC or QAM? How is the signal strength?
http://www.kiva.org/about -
connection is from cable (through a high freq . hi def splitter using the tuner in the DVD-Recorder (ATSC)
No idea about the signal strength, though -
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
ProjectX can't demux correctly recording from a precise channel
By Bilskate in forum DVB / IPTVReplies: 13Last Post: 19th Aug 2008, 17:15 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47
