For all the reasons on Matroska's website it seemed that .mkv might be the best choice to store my videos, but I've had some issues muxing them. The source file I've been testing with is an AVI with h.264 and AAC streams (it's an unedited camcorder clip). I remuxed it with mkvmerge (v4.3.0) with all the default settings.
The output video appears fine on first glance, it's the same size, it plays with the same quality and it is synched correctly. However, when seeking around in the video (in VLC, v1.1.4) the frames become heavily distorted on the first couple attempts and then VLC automatically closes the file. The original AVI seeks perfectly correctly.
What can I do to fix this?
After testing more media players, it seems the problem is with VLC rather than mkvmerge or the format itself. Using Media Player Classic HC, the mkv remux of the video actually seeks more smoothly than the original avi.
Now if I can figure out how to tag them right I think I'll be settled on mkv. -
VLC is fairly versatile, but may not be the best choice for MKV playback, especially HD. It relies more on CPU processing power, so it can be slower. I have also had stability problems with the latest versions of VLC and may end up reverting to an older version. MPC-HC, as you've noticed, is much more stable for MKV playback.
Me too!
Look here:-https://forum.videohelp.com/threads/326119-How-to-tag-an-mkv-mka-file
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
WMV jump seeking
By 1031982 in forum EditingReplies: 0Last Post: 30th Nov 2010, 16:08 -
Seeking softwared suggestions
By lapillus in forum DVD RippingReplies: 1Last Post: 11th Jan 2010, 00:09 -
Seeking expert advice - Mkv to AVI + Subs (Mencoder)
By izzy2k in forum Video ConversionReplies: 2Last Post: 7th Apr 2009, 09:28
