i ahve a client that wants his footage in 'dv' format so that he can edit on his mac
im using mpeg streamclip and im thinking that the least lossy and most likely to be compatible format that i could convert it into would be
.mov files 100% quality apple dv-pal for example
is that right or should i convert to .dv format -which from doing a trial seems to produce smaller files so im guessing would be a lower quality output??
i'd guess he's talking about DVavi - 720x576 for pal. if that's what the mov files are send him a sample and get approval.
Yeah, for a Mac, I think it's just a .dv file. I don't think you can convert it to .dv on a PC. Best to go with .mov.
Export from Final Cut Pro to format editable on PC (eg. AVI) retaining HD
By adrien23 in forum MacReplies: 3Last Post: 31st Mar 2011, 20:45 -
Converting & downscaling AVCHD to a more editable format?
By bennyboytx in forum Video ConversionReplies: 10Last Post: 3rd Jan 2011, 15:18 -
Converting .ASF files to editable format
By carbongixxer in forum Video ConversionReplies: 2Last Post: 10th Nov 2009, 14:37 -
By carbongixxer in forum MacReplies: 0Last Post: 10th Nov 2009, 13:50 -
vob to editable format
By careca in forum ffmpegX general discussionReplies: 3Last Post: 20th Sep 2007, 22:24
