  1. I have recently begun working with converting AVIs to dvd and burning them to disc. I has some smaller files I wanted to join and convert so I downloaded Virtualdubmod after doing some research on thr programs. Whenever I open the first file I get an error message popping up telling me the AVI may have been improperly joined due to incorrect time stamp. After this I can't even load the second AVI to append to this the option isn't available. I'm not sure what to do whether it is the software or whether I should see if I can unjoin the first avi ( By the way these avis I am working with were clips of Bang Bus not sure if that info would help) and try to put it together myself so I can merge. Any help would be greatly appreciated. Thanks.
    Will
    Oct 2007
    Bang Bus? Are you kidding me? Anyway try avidemux to join the files.
