(sorry if this in the wrong place)
well, thats basically the question.
Okay, i CAN edit them with Notepad, but what im basically looking for is a SENSIBLE way to edit them, which makes my life a little easier.... [EDIT: I guess i'm basically looking for a javascript editor prefferably one which is spyware free.]
I have a bunch of files i want to convert with Avidemux. It's a batch convert. my idea is to make one job with 90 times the same things, except that I change the filename
What i have now is this:
greatly simplified, i took almost everything out, there are 40 lines of script.Code:var app = new Avidemux(); app.load(\\\\"C:/#filmsnew/FF-XIII-HAH/FFXIII-01.avc\\\\"); app.video.addFilter(\\\\"resize\\\\",\\\\"w=704\\\\",\\\\"h=396\\\\",\\\\"algo=0\\\\"); setSuccess(app.save(\\\\"FFXIII-01.avi\\\\")); //app.Exit(); //End of script
but what i want is:
is there some application which lets me create this?Code:var app = new Avidemux(); app.load(\\"C:/#filmsnew/FF-XIII-HAH/FFXIII-01.avc\\"); app.video.addFilter(\\"resize\\",\\"w=704\\",\\"h=396\\",\\"algo=0\\"); setSuccess(app.save(\\"FFXIII-01.avi\\")); //app.Exit(); //End of script var app = new Avidemux(); app.load(\\"C:/#filmsnew/FF-XIII-HAH/FFXIII-02.avc\\"); app.video.addFilter(\\"resize\\",\\"w=704\\",\\"h=396\\",\\"algo=0\\"); setSuccess(app.save(\\"FFXIII-02.avi\\")); //app.Exit(); //End of script . . . . . var app = new Avidemux(); app.load(\\"C:/#filmsnew/FF-XIII-HAH/FFXIII-96.avc\\"); app.video.addFilter(\\"resize\\",\\"w=704\\",\\"h=396\\",\\"algo=0\\"); setSuccess(app.save(\\"FFXIII-96.avi\\")); //app.Exit(); //End of script
And what is better:
{A}- to have one js -file with 90 times the thing I want, or
{B}- to have 90 .JS-files?
and how do i make Avi demux "see" them in the case of {B} ????
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
How to get started with avidemux, edit and convert any video format
By Baldrick in forum User guidesReplies: 114Last Post: 16th Nov 2017, 15:29 -
how to join files in Avidemux?
By FaisalKhan in forum Newbie / General discussionsReplies: 15Last Post: 19th Jun 2015, 11:29 -
What tool/s can I use to Mux/Edit H264 in FLV container? Avidemux only does
By tigerb in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2011, 22:03 -
AviDemux: which Resize? / Edit + Recode?
By coyote2 in forum Video ConversionReplies: 1Last Post: 19th Nov 2011, 01:13 -
Avidemux edit leads to out of sync audio..
By Jmart285 in forum Newbie / General discussionsReplies: 18Last Post: 18th May 2011, 14:35
