Hi,
I have a Sony Handy Cam HDR-HC9. Until Thursday of last week it has been working fine with a Dell Latitude D820 running Windows7 Enterprise 32bit laptop. As of last week Thursday it is no longer recognized as in they are not even listed in Device Manager or under Disk Management connected via IEE1394 (small 4pin to 4 pin) or USB. I have followed these troubleshooting steps to resolve: removed driver for OHCI 1394 Compliant Host Controller and Installed the Legacy Driver for IEE1394 (Windows 7), removed driver and restarted system allowing system to autodetect installed Firewire card. I also tested on a Windows XP Enterprise Dell Latitude E6400 32bit OS. The camcorder is recognized by all Desktop systems with a 4pin to 6 pin IEE 1394 cable. No Windows updates were installed until the 19th. Any ideas?
Used several 4 to 4 pin cables and tested the firewire port on laptop with multiple devices including 2 Panasonic camcorders and it works. I tested the Sony device in multiple laptops with Windows 7 Enterprise and Windows XP Enterprise 32bit and 64bit operating systems and it does not recognize through firewire, the Sony does recognize when plugged into any desktop or workstation with a 4 to 6pin cable.
strange one. a 4pin to 6pin only has the same 4 wires as a 4 to 4 cable. the extra two pins aren't used as they would carry direct current to the device from the port. only 6 pin to 6 pin cables have 6 wires.
plug the sony in, hit play, when the video starts hit pause. then start winDV and or HDVsplit to see if they can find the cam.--
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 10:34 -
BD-Rs are not recognized
By orfajackson in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2009, 17:43 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47 -
Can't get IR Blaster to be recognized
By vanbrackin in forum Media Center PC / MediaCentersReplies: 1Last Post: 22nd Mar 2008, 16:15 -
Cd-r not recognized
By cd090580 in forum DVD & Blu-ray WritersReplies: 14Last Post: 27th Feb 2008, 03:03
