Hello,
I've got a notebook (i7 720QM, intel HM55) i use for RTMP live streaming with flash media encoder 3.1 with a cheap 35$ USB video capturer...
The encoding i'm using is H.264 main profile and it works ok with one stream but when i try to multistreams with 3 bitrates the notebook can't handle it (it starts droping frames etc...) so i'm looking for a more professional video capture card.
I was thinking on the Blackmagic Intensity Shuttle but according to their FAQ it won't work with my notebook (it doesn't have USB 3.0 native and a PCMCIA 3.0 adapter won't cut it) so this is definetly NOT an option.
The other option and only one i found so far is the Hauppauge HD PVR but i'm not sure if it will work fine with FME 3.1.
I didn't find any PCMCIA capturer...
So, any recommendation?.
Thanks!
Results 1 to 1 of 1
Video Capture PCI / USB recommendation?
By harky in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 20:04 -
help me to choose PCMCIA capture card
By byair74 in forum Capturing and VCRReplies: 2Last Post: 5th Jan 2012, 08:45 -
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02 -
USB 2.0 Video Audio capture Card
By jj3502 in forum Capturing and VCRReplies: 0Last Post: 3rd Feb 2010, 05:09 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21
