Hi. I used tsmuxer to demux the audio and video streams and then used mkvmerge to create a .mkv file. https://forum.videohelp.com/threads/309479-Blu-Ray-to-MKV-with-optioinal-multi-language...btitle-support The resulting .mkv is playing ok but DXVA isn't supported when played using MPC-HomeCinema, hence resulting into a very high CPU usage. Could anybody tell me how to create DXVA supported .mkv? Do I need to change the settings somewhere or do I need some different software? Thank you.
You might try running DXVA checker to see if it's working on your video card first: http://bluesky23.hp.infoseek.co.jp/en/index.html If so, it's probably a player setting.
And welcome to our forums.
DXVA is supported on my GPU.
It is mainly the blu-rays with VC-1 video stream that I am having problems with. When playing directly from bluray or .m2ts file, GPU acceleration is perfectly fine.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Problems after converting mkv to blu-ray format
By BigGreenie in forum Video ConversionReplies: 17Last Post: 7th Jan 2012, 06:27 -
converting blu-ray to mkv without losing quality
By Arkadietz in forum Blu-ray RippingReplies: 5Last Post: 3rd Oct 2011, 17:31 -
What is best method of converting Blu-Ray to MKV?
By leejayd in forum Newbie / General discussionsReplies: 11Last Post: 12th Apr 2010, 15:46 -
converting blu-ray to mkv without losing quality using SUPER
By nymphadora in forum Blu-ray RippingReplies: 8Last Post: 24th Jul 2008, 10:36
