I have a 17GB folder with many subfolders which I need to store on standard 4GB DVDs.
Is there a program which allows you to just select that main folder, select the DVD format and the software calculates everything else automatically, just prompting you to put new DVDs in the drive?
Please respond with a solution, anyone...this is a huge problem if done manually.
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
I don't think this one does it "on the fly" but it might. I've used it but haven't experimented too much with it.
http://hcidesign.com/dvdspan/ -
Also the files must not be split in any way as a byproduct of splitting on many DVDs, only calculated to optimally fill each DVD.
P.S.
DVD span is only trial with limited functionality."The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
You're right. Don't even try DVDSpan. Don't read the instructions or the FAQ. Just ignore it. Forget I even mentioned it.
Check out SizeMe at http://lars.werner.no/?page_id=2 - does optimal file allocations.
incremental backing question
By gordes04 in forum ComputerReplies: 0Last Post: 12th Aug 2011, 18:21 -
What current recorders have flexible/incremental recording?
By Bix in forum DVD & Blu-ray RecordersReplies: 57Last Post: 31st Oct 2008, 12:07 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19 -
Need suggestion for cheap or free "incremental" backup software x
By yoda313 in forum Off topicReplies: 5Last Post: 6th Jun 2007, 11:13 -
Software for differential/incremental backup.
By lordhutt in forum ComputerReplies: 8Last Post: 21st May 2007, 02:04
