    Dec 2005
    I used videodub to delete a couple of seconds of an avi video and then saved the resultant file. The original file is 21 MB and the shortened avi is 1.2GB. Can someone tell me why that's happening and how to get a resultant file no larger than the original??
    Feb 2008
    Twin Peaks
    Did you have both the video and audio set to "direct stream copy" ?
    Dec 2005
    Thank you. The audio was set but not the video. That solved the problem.
