Yes a new post. Yeah, the aspect ratio conversation was/is one of the longest threads.
Anyway, I would like to ask for your guys advice on a A rated (3 1/2 out of 4 stars) quality for DVD (muxer engine). And also state which one's are NOT good. Please note all material will already be put into mpeg-2 format for dvd as created by Quenc.
The muxers I have used in the past for SVCD was:
BBmpeg
Muxing Machines I heard that are good for DVD:
Muxman (with the ability to ADD buttons--Mixed reviews)
Tmpgenc (tsunami)
Obviously, I cannot afford scenarist. I cannot even afford a $500 solution. We are talking about $125 or less. So which muxer have you guys not had any problem with or minimal problems with? would you recommend Muxman? Or would you recommend buying the tsunami encoder. Please note, I just need a muxing machine NOT an encoder. Or do you know of an idependent muxer with just a muxer and I could feed it to another author program?
Ts Muxer Blues
By romanticwarrior in forum Authoring (Blu-ray)Replies: 3Last Post: 2nd Dec 2010, 09:17 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 04:57 -
RMVB Subtitle Muxer
By El Heggunte in forum SubtitleReplies: 0Last Post: 11th Jul 2010, 21:49 -
Resolution with ts muxer ??
By bobotheclown in forum Authoring (Blu-ray)Replies: 6Last Post: 27th Nov 2008, 18:42 -
menc muxer problem ?
By Ahmed28 in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2008, 07:27
