I am preparing to transfer over 200 aviation films (documentaries & features) from my archive 3/4" cassettes to digital video file storage (before the tape deteriorates). I have a good capture card (Osprey) and several good capture programs. My plan is to capture the films first in an intermediate file format then clean up, enhance, reframe if necessary, etc. using Discreet Cleaner XL to generate a final mpg file for permanent file keeping. Discreet will not accept mpg files as input so I will have to capture in another format. My capture programs allow capturing in avi, asf, wmv, mov and flv formats. Can anyone save me the research time and tell me which of these formats is best for raw digital input to a program such as Discreet Cleaner? Or are they all about equal in capture quality? I will not be saving the raw capture file it will only be used until the final mpg file is done and then I will be done with it.
Is your Win 2000 profile accurate?
Which Osprey card? Most over compress which may not be optimal.
Of the choices only avi and mov have potential. Both are containers. What codecs?
Of course uncompressed or low compressed codecs work best. What softwre are you using?
The 3/4" Umatic deck ideally needs a TBC. Does yours have one?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
One of the lossless formats may be a good choice. HuffyUV and Logarithm Lossless Video Codec are a couple. I haven't tried it, but Alparysoft Lossless Video Codec is another. If you can't use any of those, others here may have some suggestions.
Lagarith is a bit more compact than HuffyUV. I don't know about Alparysoft. They all take a lot of hard drive space, so be prepared for that. Other choices may be one of the more lossy AVI type formats, with a high bitrate. -
Win2K is the opsys.
My card is an Osprey 210.
The codecs available in The Debut Video Capture program are almost 20 in number. I have other capture programs such as Videopad but Debut seemed the easiest to use. I defaulted to the Microsoft MPEG-4 codec since I was not sure of the other choices.
Debut Video Capture.
I have three 3/4" decks, 2 Sony 5800's and one Sony 5850. Not sure if they include TBC. -
Your Celeron 2.66GHz is on the slow side to do much real time encode during capture. The Osprey 210 seems to lack any hardware assist. I agree Huffyuv is your best intermediate format since processing required is less than Lagarith. Test them both. I haven't used the others.
http://www.viewcast.com/products/osprey-cards/osprey-210
Discreet Cleaner XL should encode to DVD MPeg2 (704x480i or 720x480i upper field first >6 Mb/s (average). I'm not sure if Cleaner XL will accept huffyuv directly.Recommends: Kiva.org - Loans that change lives.
Raw DV vs. Type 2
By jlorelle in forum Newbie / General discussionsReplies: 21Last Post: 13th May 2013, 00:50 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 11:25 -
Any such thing as a raw capture?
By VHSMadness in forum Capturing and VCRReplies: 12Last Post: 24th May 2011, 07:43 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 18:22
