my thinking is in both instances the result will be visually close or identical, but mathematically night & day. i also suspect the algorithm employed by specific encoders in enough of a wildcard to render all conjecture useless. in that case, i'd like to hear practical result-driven observations from people who've done this
if i encode a medium-quality pre-filtered source in mpeg2, decode the result(in yuv colorspace), then re-encode using the exact same encoder & settings....discounting any bit errors introduced by the idct algorithm, how mathematically identical will the result be. close? not close at all, but still visually identical or not?
if i encode a medium-quality pre-filtered source in mpeg2, decode the result(in yuv colorspace), phase shift all bottom fields 1 frame(no colorspace conversion), then re-encode using the exact same encoder & settings....discounting any bit errors introduced by the idct algorithm, will the alternating scan nature of mpeg2 encoding still preserve the mathematical signature of the individual displaced fields
Results 1 to 1 of 1
advantages of transcoding mpeg2
By codemaster in forum EditingReplies: 4Last Post: 26th Apr 2012, 16:11 -
deinterlacing source mpeg2 when transcoding it to dv
By codemaster in forum EditingReplies: 14Last Post: 20th Apr 2012, 13:18 -
Question about HD MPEG-TS transcoding
By fotty in forum DVB / IPTVReplies: 23Last Post: 4th May 2008, 13:08 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 14:23
