I want to convert the dvd "Nemo" to either avi or mpeg so that I can cut 2 minute slices of the movie for my students and have them practice the lines (I am teaching ESL). I have been able to copy the dvd onto my hard drive. I have found several tools that will convert the files to either avi or mpeg but I am having trouble getting the English subtitles to come along with it. I tried using GTK. It has an option to choose the subtitles but there are no subtitle files displayed to choose from.
I have chosen the vob file to convert. Is this correct? Am I doing something wrong or just haven't found the right tool yet?
Try converting the DVD to ISO using dvdhddecrypter then use fairusewizard to convert to avi making sure to check the box to include the subtitles.
Hi, i was converting a dvd to avi(with subs) using autogk and Xvid4PSP, and i can't change the size,font,position or color of the subs.
I tryed every possible way and tool i know of for extracting/editing the subs, and my problem was that the subs are not latin(English etc) but Cyrillic(Macedonian) but named as English in the DVD, so the OCR gives me "@^78605j_+#@@@" instead of the actual words.
The only way that worked.. is to manualy edit the idx sub file using notepad.
So my question is, is there any way of editing the size, font, position, color of the subs using Xvid4PSP for example, or any other "converter" when converting from dvd to avi including the subs of the dvd? -
Well.. i forgot about VobSub Configure
Yes , i know that OCR is the way to go, but it didn't work ("Cyrillic(Macedonian) subs, but named as English in the DVD").
Anyway, i already found the solution by editing the idx file in notepad, and i fixed the positioning, color and font-size this way, and i almost never do this kind of conversions.
I just wanted to know if there is some "one gui way" to do this, like with textsub in virtualdub etc.
Thanks Manono.Last edited by pirej; 20th Sep 2010 at 19:28.
How to include subtitles when converting avi > mpeg > dvd ?
By buzzsaw in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2011, 10:05 -
converting subtitles from avi to dvd???
By denze1 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2010, 11:39 -
Converting OGM files to AVI/MPEG with subtitles
By StevoK in forum Video ConversionReplies: 1Last Post: 4th Feb 2010, 01:50 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Help Adding Subtitles to an AVI while converting to an MPEG
By canas15 in forum ffmpegX general discussionReplies: 8Last Post: 26th Dec 2008, 23:28
