Is it possible to record HDV (1440x1080) on ordinary mini DV Cassete.What's the difference when use HD cassetes comparing to quality or drops for example, because these HD cassetes are much expensive then mini DV.
Regards.
	QUALITY HAS A NAME
	Not a quality issue but a reliability issue.
 DV25 and HDV are both 25 Mb/s data streams so bits are bits right?
 Not quite.
 DV25 records all frames so a glitch will affect one frame. HDV is MPeg2 with 15 frame GOPs so a glitch could affect 15 frames (half second). That said, the probability of a half second glitch is low.
 Consumer MiniDV tape has other problems. It is stretchy and records a lower signal to noise so data loss is more probable. Pro MiniDV tape has dropped in price to consumer levels (or less than stores). Pro MiniDV tapes have a high quality backing intended for fast wind pro decks and record a stronger signal.
 I use Panasonic AY-DVM63PQ for both MiniDV and routine HDV. On sale they are often $2.50 or less.
 http://www.tapeonline.com/products/panasonic-mini-dv-ay-dvm63pqus
 For special shoots I'll use the HDV marked tapes.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  Mini DVD tape: HD vs Regular vs HDVBy CliveJ in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2011, 20:34
  What Mini DV Cassetes for HDV recordingBy MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Jun 2011, 06:01
  Alternative to the expensive sony HDV cassetesBy PeterK in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 17th May 2009, 11:03
  HDV recording on mini DV cassetesBy MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Oct 2008, 07:25
  HDV Camera and CassetesBy MI6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Apr 2008, 19:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
