Ok, for some reason, my VCDs seem to be running at almost 15fps. My source files are 29.97fps and I encode them at 29.97fps. But when I play them back on VCD in a DVD player or even the MPEG 1 file on the computer, it's choppy(both normal scenes and panning scenes). When I step through the playback slowly, I noticed that about every 2 frames, it repeats a frame. The repeated frames are the same images as the frames before them, but you can notice that the compression is a little different.
Since, I really haven't seen any other VCDs, I don't know if this is normal or not. Has anyone had this problem before??
Results 1 to 1 of 1
Converting NTSC DV AVIs to H.264
By paleGreen1 in forum Video ConversionReplies: 10Last Post: 11th Apr 2012, 00:33 -
AviSynth working with Y8 uncompressed AVIs and MVTools motion interpolation
By a1s2d3f4 in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2010, 21:32 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 08:20 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Converting VOBs to AVIs
By HartsVideo in forum DVD RippingReplies: 61Last Post: 3rd Nov 2008, 16:23
