Just wondering if there are any viable alternatives to TMPGEnc Xpress (that include all the filtering, picture adjustments, etc)?
Thanks.
(I should add that work under Win7 64-bit)
With all due respect, I'm not looking to author BDs, and I don't see any software listed on your page that provides for the filtering capabilities that TMGEnc XPress does. Am I missing something?
Or VirtualDub -- if you want AVI output. (As I understand it, there is an experimental version of VirtualDub that allows the use of external output filters -- that will let you create other file types like MPG, MKV, etc.).
i can think of a few off the top of my head:
avidemux (free, lots of features)
xmedia recode (as above)
avs video editor
ulead video studio
cyberlink power director (offers gpu accelerated h264 encoding, pretty slick)
free demos are available for the last 3. -
I'll check out xmeda recode and ulead, as I'm not totally familiar with them (I never encode to h264). All I'm looking to do is clean up existing files, and change formats - sometimes to Xvid, sometimes MPEG1, sometime MPEG2, etc. TMPGEnc just seems to have the most intuitive interface and the most options & filters available. I've tried Xvid4PSP and have not been happy with the results. If I just wanted format conversion, I can get that from Super (which I've never had any problems with) - it's the filters and picture options I'm looking for. (AVIDemux I've used, doesn't have the options, neither does VD or VDMod).
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
