  1. I have 8 vob files i want to join up into 1 file, my hard drive has 48GB of free space, and total of these 8 vob files only total 4.23GB the files i want to merge are as VTS_01_1 to VTS_08_1 but it just says error not enough disk space
    And you have ripped the dvd vob files to your hdd? And if it's a fat32 partition you have a 4gb file size limit.
  3. I have files on my HD and its a ntfs drive
    so what you mean is vobmerge can only merge a limit of 4GB
    Jan 2007
    Republic of Texas
    This is a little quirk in VobMerge. Just make your destination the same folder (VIDEO_TS, presumably) as your source .vob files. I had the same problem, until I kept things in the same folder.
  5. well that seems to have solved my problem many thanks
