Ladies and Gents, i have a daughter whos growing up bilingual. I.e. i would like to have the italian audio trace of L'era glaciale (Ice Age) from the italian dvd, the german audio trace from the other dvd and bring them together on a new dvd, so i dont have to bring everytime both dvds when we travel. And i would like to choose the language from the setup menu. Is there any software permitting me so?
Are Italian and German already on your DVD or are you trying to combine two DVDs?
They are both PAL format so as long as the movie lengths of both DVD are the same then it should be pretty easy. My DVD authoring program can only accept ONE audio track because it is so old but I believe there is even a freebie program(or two) that can give you a DVD with two audio tracks.
Your first step is to rip the DVDs to your hard drive with something like DVDFabDecrypter(there is a FREE portion of that program). -
You could join two dvds with dvd shrink in the reauthoring mode.
Or if you want same video with two audio tracks it gets much more complex, you have to demux the video and audio with pgcdemux, use muxman to author a new dvd with the video and both audio tracks, add back menus to the new authored dvd with vobblanker. But you wont be able to choose audio from the setup menu, you have to use choose from the remote control audio-button. -
so i can sue dvd shrink to rip the two dvds in two folders and then open the two folders in dvd shrink in order to reauthor the new dvd? afaik dvdshrink lets me handle just one folder at a time.
You join under the reauthoring mode, you can add video from two folders there. See http://www.dvdshrink.info/reauthor_basic.php
List audio streams on DVD
By CaptnKebec in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2009, 19:19 -
Removing certain audio streams/subtitles from a DVD
By SiM99 in forum DVD RippingReplies: 18Last Post: 7th Feb 2009, 02:46 -
How to add streams to WVC1 (WMV HD)
By ChileanGuy in forum Video ConversionReplies: 0Last Post: 21st Jan 2009, 12:16 -
Change order of dvd audio streams
By jujuandhuhu in forum AudioReplies: 3Last Post: 18th Mar 2008, 09:19 -
DVD Audio Streams
By jeh in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2008, 16:23
