i converting MKV file with video codec H264. i use ripbot 264 to converting it for my PSP. when i done it, the audio and video is not syncron. so i try use mkvewizard to extract the video, but the file extension is *H.264.
so, how i can convert video H.264 with best audio ?
all of my mkv with h264 video is not syncron with audio when my ripbot has done it . . .
and the audio is ac3 or whatever. i forget it. . .
forgive me for my bad english. . . .
H.264 is just the video stream - it has no audio. After extracting the streams you should have a H.264 video stream and a .AC3 audio stream.
Have you tried Xvid2PSP, which will happily do this conversion for you ?
If ripbot is failing with every conversion then either you are doing something wrong, or your system has some fundamental problems.Read my blog here.
well, i try many video
example : Nurarihyon no Mago [Phuzy]_Nurarihyon_no_Mago_-_05_(1280x720_h264)_[A041D46F].mkv
all mkv with name h264 when it done is not syncronize between audio and video.
i have try format factory, it done but the video quality is very suck. the ripbot conversion video very better. but with problem in sincronize between video and audio. >_<
editted :
my friend said it because the B-frame. what is B-frame ?Last edited by ageega; 17th Sep 2010 at 06:49.
MKV (X264) 4:3 to MP4 (H264) 16:9 with black borders
By itsonlyme in forum Video ConversionReplies: 2Last Post: 25th Oct 2011, 11:10 -
MP4 vs MKV for h264 content?? Based on HD PVR capures
By dynamis_dk in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2011, 11:22 -
Do you prefer mp4 or mkv for h264 video?
By yoda313 in forum PollsReplies: 18Last Post: 18th May 2009, 14:56 -
MKV [h264/aac] to mp4 conversion problems...
By DestructoEH in forum Video ConversionReplies: 6Last Post: 12th May 2009, 20:19 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06
