Hi there, I'm trying to open up some MPEG-4 files I got using protected softs Youtube 2 video converter. Is there something special I need to do to open MPEG-4's in TMPGEnc?
				Results 1 to 12 of 12
	I do plan on burning it to DVD, but I prefer TMPG because its a tool that I'm familiar with and it seems to encode a whole lot faster than other encoding tools (the built in transcoder with Final Burner, which I use to burn DVD's, takes *forever* to transcode files into something you can burn to DVD).
 Heres what I got with Mediainfo:
 General
 Complete name : C:\Users\Stephen\Desktop\DVDtest.avi
 Format : MPEG-4
 Format profile : Base Media / Version 2
 Codec ID : mp42
 File size : 103 MiB
 Duration : 6mn 57s
 Overall bit rate : 2 079 Kbps
 Encoded date : UTC 2009-11-14 02:20:09
 Tagged date : UTC 2009-11-14 02:20:09
 gsst : 0
 gstd : 417726
 gssd : BADC20888HH1284611489841720
 gshh : v16.nonxt5.c.youtube.com
 Video
 Format : AVC
 Format profile : High@L3.1
 Format settings, CABAC : Yes
 Format settings, ReFrames : 3 frames
 Codec ID : avc1
 Duration : 6mn 57s
 Bit rate mode : Variable
 Bit rate : 1 943 Kbps
 Maximum bit rate : 2 937 Kbps
 Width : 1 280 pixels
 Height : 720 pixels
 Display aspect ratio : 16:9
 Frame rate mode : Constant
 Frame rate : 29.970 fps
 Resolution : 24 bits
 Colorimetry : 4:2:0
 Scan type : Progressive
 Bits/(Pixel*Frame) : 0.070
 Stream size : 96.6 MiB (93%)
 Title : (C) 2007 Google Inc. v08.13.2007.
 Tagged date : UTC 2009-11-14 02:20:11
 Audio
 Format : AAC
 Format version : Version 4
 Format profile : LC
 Format settings, SBR : No
 Codec ID : 40
 Duration : 6mn 57s
 Bit rate : 132.3 Kbps
 Maximum bit rate : 151 Kbps
 Channel(s) : 2 channels
 Channel positions : L R
 Sampling rate : 44.1 KHz
 Resolution : 16 bits
 Stream size : 6.63 MiB (6%)
	TMPGEnc is one of the BEST tool available.
 Try converting HD MP4 (1280x720 (720p) or 1920x1080 (1080p) HD) to SD AVI (640X360 AR 16;9) first with video bitrate approx 2000 kbps and audio 320 kbps 48000 Hz mp3. you may wish to use free tool HERE for conversion OF mp4-HD to avi-SD.
 -or-
 use any good video converter of your own choice!Last edited by Bonie81; 18th Sep 2010 at 18:39. Reason: addition
	deadrats
 for two reasons
 1) to maintain proper aspect ratio, while mp3 leaves many choices open for audio encoders.
 2) DVD-SD 720x480 will be automatically taken care by TMPGEnc.
	but there are a number of things wrong with your line of reasoning:
 1) the original audio is a vbr with an average of 132 kb/s and a max of 151 kb/s, encoding to mp3 at 320 kb/s isn't doing anything other than blowing up the file size, there is no additional audio information that can be added, likewise the sample rate of the source if only 44 khz, encoding to 48 khz doesn't improve quality at all since the data above 44 khz doesn't exist in the source.
 2) the source is 1280x720 which means it's composed of 921600 pixels, 640x360 is composed of 230400 pixels, almost 1/4 less pixels, the quality of the file will be in the crapper, a better option would be 720x404 which likewise has an aspect ratio of 1.78 but is composed of 290880 pixels for better quality.
 a better approach would be to simply feed the file into tmpg and simply choose the "dvd-compliant" profile which will do the appropriate resizing for him automatically.
 to the OP:
 if you're using tmpg express, then it should accept the mp4 input no problem, if you're using the original tmpg encoder you may have to create a dummy avi file or use an avisynth script to get it to accept the mp4 (though i have fed mp4's into the original tmpg with no problem).
 you may also want to try an ffmpeg based tool and compare the outputted quality, try winff or avidemux, you may like them better (and they're free).
	I tried moving the Directshow filter to the top and no dice. I also added .MP4 to the filenames and no dice there either. Oddly enough Windows 7 has .AVI on the icons for the files and also the properties tab lists it as an AVI file, even though Mediainfo lists it as an MP4. I'd really like to be able to use TMPEG to open this kind of file because the encoding speed is so superior, I don't feel like sitting around all night waiting for one of these DVD authoring tools to transcode the video files at a snails pace.
	I don't think you changed the extension. Changing it probably won't help but... Windows 7 normally won't let you change extensions. You have to disable the "Hide extensions for known file types" option. Organize -> Folder and Search Options -> View tab -> Hide Extensions For Known File Types (remove the checkmark). After that you'll be able to see the extension and change it.
 You can use AviSynth scripts with TMPEGEnc. Again, you'll need a Directshow MP4 file reader, an AVC decoder, and an AAC decoder. And you'll need to install AviSynth, of course. Then you use a simple script like:
 Use a text editor (Notepad) to create the script and give it the extension AVS. Open the AVS file with TMPGEnc or any other encoder that accepts AVS scripts.DirectShowSource("filename.mp4")
 TMPGEnc Free is one of the slowest MPEG2 encoders around. CCE is one of the fastest. HcEnc is free and much faster the TMPGEnc.Last edited by jagabo; 20th Sep 2010 at 08:06.
	Thanks for the tip  maybe it is just fast compared to the built in ones with my DVD burning program. maybe it is just fast compared to the built in ones with my DVD burning program.
  mpeg4 AVC issues with RipBotBy nikemouse in forum Video ConversionReplies: 1Last Post: 17th Mar 2010, 04:57
  Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic'sBy drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 09:37
  TMPGEnc Issues with length of movie?By doctorgonzo in forum Video ConversionReplies: 1Last Post: 11th Apr 2009, 11:30
  TMPGEnc Issues.........By RKelly in forum Authoring (DVD)Replies: 5Last Post: 19th Jan 2009, 07:15
  Getting DVDs to MPEG4-SP or MPEG4-AVCBy WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
