  1. I am very new to all this, I need to edit FLV files with imovie so I need a quick conversion for large files. I downloaded ffmpeg with all the files it needed, and it is running fine. However after I chose the file I want to convert, after I click "encode," it says finished in the progress window but nothing happens and I can't find my encoded files anywhere. Am I missing something? Where will I be able to find my files?
    I saved them on my desktop so they will be easy to find but I sill can't find them anywhere...
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Please post the content of the Process Information log, accessible by pressing the blue "i" in the ffmpegX Progress window, after a conversion attempt. That should help up figure out what is going on.
