I am using the free version of Altysoft Video Converter 3.20.
I am trying to burn an MPEG-2 SVCD of "Godzilla 1998" movie,
downloaded in Matroska (MKV) format, onto an ordinary CD-R.
The movie is in H.264, 1280 x 538, 23.98 fps, Ultra-widescreen.
It is some 2 hours 18 minutes long.
The original file is some 600 mb big.
I don't have a DVD burner, just an ordinary CD burner.
To save space, I have used the converter to convert it to MPEG-2,
480 x 272, NTSC, 29.97 fps, 1152 kbps, 16:9 widescreen. This uses
up about 11 mb per minute, just a little more than an MPEG-1 file.
I used the spltter to cut out the ending cast, reducing it to 2 hours 10
minutes.
This comes to some 1,200 mb, which I split with a Solveig's Video
Splitter into two exactly equal parts of 1 hour and five minutes
long, about 600 mb, each.
I then used Nero 6, turned of standard VCD compliance, and
tried to burn the first part. However, inexplicably, Nero reports
the first part taking up some 800 mb of space, too much to burn
on a normal 700 mb CD-R.
So I tried with the second part, and it reports it taking about 600 mb,
which I proceeded to burn.
The CD-R plays alright on Media Player Classic 6.4.9.1,
which I think uses the FFDSHOW codecs, though it cannot
display Ultra Widescreen format.
Do you think it would play on my home standalone DVD player,
one of those China-made "Weige" brand (Model DVD-168) models,
which has "SVCD, VCD, CD-R, CD-RW" printed on its case ?
__________________________________________________
Closed Thread
Hi, SVCD has strict specifications, as seen from http://en.wikipedia.org/wiki/SVCD
For SVCD encoding I would use avisynth to frameserve to the free version of TMPGEnc : http://www.tmpgenc.net/en/download.html
TMPGEnc can also cut your encoded file as you desire.
You're also going to have to resample the audio.
Tham, Asking about downloaded, copyrighted videos is in violation of our rules. Please read our rules before posting: https://forum.videohelp.com/topic124514.html
Our warning system:
https://forum.videohelp.com/topic170319.html
Moderator redwudzLast edited by redwudz; 16th Sep 2010 at 15:27.
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57 -
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 13:14 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 13:25 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 01:35
