Hi all,
I want adjust the audio level of all files in a BD-R that I plan on building in multiAVCHD.
There`s a "gain" feature that I can adjust in each file, please which number may I type in each file to make all of them sound the same level, say normalized to 0dB (maximize peak) ? Does it depend on the original level of each file or is there a common setting that I can type in for all files ?
For example, in Sound Forge I say "normalize peak value to 0dB" and it works regardless the original levels, can I type something like that in multiAVCHD ?
Also, the software freezes in my Windows 7-64bit OS, has anyone experienced similar problems ?
Thanks,
Zetti
Results 1 to 1 of 1
DVD rippers with audio gain?
By ferreter in forum DVD RippingReplies: 4Last Post: 4th Mar 2011, 21:24 -
HELP : FFMpegX PSP Audio GAIN not available ? ? ?
By aerolex in forum Video ConversionReplies: 1Last Post: 17th Dec 2009, 07:33 -
GH1 auto-gain audio
By kippard in forum AudioReplies: 0Last Post: 8th Oct 2009, 02:45 -
Application to lower audio gain of MPEG file?
By headless chicken in forum MacReplies: 6Last Post: 26th Dec 2008, 08:41 -
Audio gain in ffmpeg
By pdec in forum ffmpegX general discussionReplies: 3Last Post: 12th Aug 2008, 06:45
