I just bought the Fatal1ty Pro and so far i'm impressed with it. However i can't seem to figure out how to disable either output. Here's what i mean, i have a 2.1 cambridge soundworks setup plugged into the green output of the sound card. I also have the optical output of the sound card running to a dolby decoder for my surround sound headsets. Both work just fine, however the audio always outputs to both devices. There doesn't seem to be any way to disable either output within the creative software, so in essence i could switch from one output to the other. In control panel, under sound on the playback tab, the default selection is Speakers (Creative SB XFI). Just beneath that i see SPDIF Out (Creative SB XFI) says 'ready'. If i try to disable the Speakers option, and then set the SPDIF as default i get no sound from either output. There has to be a way to switch between either output. Does any one know if that can be achieved?
System specs:
Phenom II X4 955 BE
MSI NF750-G55 MOBO
8 GB Kingston HyperX ram
MSI Radeon HD5750
Windows 7 Ultimate 64-bit
Have you ever tried some "non-official" drivers for your sound card?
As a rule, the drivers (and especially the applications) from the Creative Lies have always sucked.
If I were you, I would have looked for a second-hand "audiophile" card.I just bought the Fatal1ty Pro
What are the uses of a "X-Fi Titanium Fatal1ty Champion Series" ?
By Engineering in forum ComputerReplies: 4Last Post: 14th Dec 2009, 17:33 -
HELP!! Dual Layer Problem with Titanium 10
By mnelson220 in forum MacReplies: 20Last Post: 21st Jan 2009, 00:50 -
ExpressCard Sound Blaster X-Fi Xtreme Audio Notebook
By AuroEdge in forum AudioReplies: 0Last Post: 7th Oct 2007, 02:14 -
Toast Titanium
By finalvideoproduction in forum MacReplies: 2Last Post: 10th Sep 2007, 17:27 -
Toast Titanium not responding....then it does
By SonicMix in forum MacReplies: 5Last Post: 5th Sep 2007, 14:59
