How have i to set Blu-ray Ripper to conveert BD to a mkv file?
I'd like to know what bitrate audio is better, high or medium quality video, sample rate, channels and so on.
Best regards.
Depends on what software you are using and what you want to play it back with. I use AnyDVD to rip the BD to my hard drive, then process with RipBot to a 8.5GB MKV with 640kbps 5.1 AC3 audio. I choose that size so I can back up the MKV to DL DVD disc. To obtain a set size, I use two pass encoding, setting the output size to 7900MB. The audio defaults to 640kbps 5.1 and the video to 4.0 profile. I don't change any of the other defaults. The quality is quite good, even on a large screen.
The downside is this can take quite a bit of time. With my six core 3.5Ghz CPU, about 5 hours. With a slower dual core, it could take twelve or so hours.
If you aren't concerned about the size, use the default CQ 22 settings as the conversion will be quite a bit quicker.
Other ways to do this also.
And welcome to our forums.
I use Pavtube Blu-ray Ripper and i can find this setting fields for mkv:
Video
codec h264
Size 1920x1080
Bitrate medium or high quality
Frame 30
Audio
Codec AAC or MP3
Sample rate 44100 or 48000
Bitrate from 128000 up to 448000
Channels Stereo or 5.1 -
Creare un mkv dal blu-ray (utilizzando Pavtube Blu-ray Ripper) con queste impostazioni è corretto?
Video:
Codec h264
Bitrate medium quality
Frame 30 fps
Audio:
Codec AAC
Sample rate 48000
Bitrate 448000 bps
Channels 5.1 -
I made a mkv from blu-ray (utilizzando Pavtube Blu-ray Ripper) with these setting:
Video:
Codec h264
Frame 30 fps
Audio:
Codec AAC
Sample rate 48000
Bitrate 448000 bps
Channels 5.1
Is it right? Or is it better otherwise? -
Bitrate medium quality doesn't say much....does it look okey? Then it's okey.
And you can use FREE rippers and converter like dvdfab hd decrypter and convert with ripbot264.
Best Blu-Ray Ripper?
By Ar-Pharazon in forum Blu-ray RippingReplies: 82Last Post: 15th Feb 2015, 03:27 -
Need help using Xilisoft Blu-Ray ripper
By billw6560 in forum Blu-ray RippingReplies: 10Last Post: 10th Sep 2013, 23:46 -
A good Blu Ray Ripper
By pepegot1 in forum Blu-ray RippingReplies: 6Last Post: 28th Apr 2011, 21:19 -
Xilisoft Blu Ray Ripper - Does Anybody Test This Program?
By devilcoelhodog in forum Blu-ray RippingReplies: 4Last Post: 24th Mar 2011, 14:03 -
xvid4psp, encoding settings suggestions please, blu-ray-> blu-ray
By runLoganrun in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 08:07
