Hey folks...
Been having a bit of trouble with expoting my finished edit... The first time towards the end there were some missing video but not sound so the video went out of sync. I now believe this was due to interupting auto save, but before i found that out i started messing with all the export options like an idiot.
now all exported quicktime files come up as some random icon in my dvd authoring software... they wont play in the normal quicktime player as it says they are some unknown format. doh!
can anyone take a look at the default settings so i can put my thing back to normal for me... at least if i do that and it doesn't work i can cross it off my list and find if there's another reason...
if (from what i said) anyone can tell its not that problem and knows a solution by all means let me know. tearing my hair out here as it took me ages to cut and now i'm falling at the last hurdle...
thanks in advance
K
Results 1 to 1 of 1
Custom Export Settings (Premiere Pro CS4) *Height
By BoLane in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 24th Jul 2013, 19:47 -
Need to export movie in Premiere Pro 1.5. What settings?
By vid83 in forum EditingReplies: 5Last Post: 23rd Mar 2013, 17:13 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 17:45 -
FCP Downconvert and Export 16:9 to Quicktime
By Jeff_NJ in forum MacReplies: 1Last Post: 24th Oct 2008, 11:45 -
Export to FCP Quicktime Movie
By James in HD in forum MacReplies: 2Last Post: 2nd Dec 2007, 08:43
