Hi we were wondering if anyone could advise on the following assuming a 500Gb ATA-100 HDD, 4Gb ram, 3gz latest pentium:
How long would it take to convert a 1 hour 32gb mpeg2 captured at 50 mbps to 1 hour h264 compressed F4V file or similiar?
Any help would be much appreciated.
Thanks Steve
"latest pentium ?" they don't make those anymore , what model exactly?
ATA HDD - they don't make those either . It must be an older P4-3Ghz model
What dimensions, what bitrate ?
For SD material it would probably take 3-6 hours depending on quality settings . If you got a more recent computer like an i7, it might take 20-30 minutes (depending on quality settings ) . And if you have any filtering (e.g. deinterlacing) add to that time -
Thanks for the quick response.
I've been informed the computer is more likely to be a spec similar to:
IntelŪ Core™ i3 Processor 540 (3.06GHz, 4MB)
1GB ATIŪ Radeon™ HD 5450 graphics card
4096MB 1333 MHz Dual Channel DDR3 SDRAM [4x1024]
1TB Serial ATA (7200RPM) Hard Drive
Dimensions we assume to be PAL 720x576
Bit rate would 768 kbps
H264 in MPEG2-PS
By vid2me in forum Video ConversionReplies: 15Last Post: 18th Nov 2010, 14:10 -
Converting MKV (or h264) to MPEG2
By DeathStalker77 in forum Video ConversionReplies: 25Last Post: 11th May 2010, 21:15 -
H264 to MPEG2, best way ?
By boulder in forum DVB / IPTVReplies: 9Last Post: 30th Aug 2009, 17:49 -
MPEG2 TS HDTV to H264
By Dr_Layne in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 17:08 -
Mov h264 to MP4/h264 Conversion
By Scooter_NJ in forum Video ConversionReplies: 2Last Post: 26th Mar 2009, 10:07
