Hi I have several .avi tv clips. whats best and easiest program to join them up. then after they have been joined to convert to vob files as my player only play VOB
Instead of hijacking a thread with something that has nothing to do with the OP's question open your eyes and find the "TEST" forum or start your own thread asking how to do it.
Oop's.. just saw his outstanding new post....
See ya hopefully, NOT!!!
@ natty
If all the AVI's are the same specs you could join them with avidemux first or what baldrick suggested if you don't mind slight pauses between the video's. -
Hi I downloaded avidmux I have several short avi clips to make as a DVD IE: VOBs as my DVD player wont play avi. I don’t understand how to join all of these into 1 big avi to be then converted into a DVD. I tried convertXtoDVD, but say about 9 clips on 1 DVD, when I play it on my Home DVD Player it only plays 1 clip not the others I burnt on the DVD which was 9 clips. also I don’t have a clue how to use this avidmux to join all avis into one. I did try append for 2nd clip but it said about not same video dimensions. plus when I 1st added the 1st avi it said about build VBR and index not up to date. can anyone help me what's best program to burn these several avi clips to a DVD. as VOBS
btw baldrick didn’t suggest anything as you quoted above
I have a friend of mine recorded quite a few seasons of a TV show as .avi 10 seasons with about 24 avi clips in each. I have tried ConvertxtoDvd but when I play a DVD on home player which contains about 8 clips from one season it only plays the one clip yet there is about 8 clips on the DVD. what's best program or way to do this as my home DVD player wont play aviwhat baldrick suggested if you don't mind slight pauses between the video'sLast edited by natty; 21st Sep 2010 at 11:02.
Joining avi's
By Frisco656565 in forum Video ConversionReplies: 5Last Post: 9th Sep 2008, 22:29 -
joining avi files
By king2136 in forum Authoring (DVD)Replies: 4Last Post: 1st Oct 2007, 15:30 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 11:05 -
joining 2 avi movies
By php111 in forum Newbie / General discussionsReplies: 25Last Post: 2nd Aug 2007, 19:30 -
Joining two AVI's???
By Kayfabian in forum EditingReplies: 1Last Post: 17th May 2007, 19:07
