I just recently pick up a new hobbie for video editing and need some advice.
I've been following this group called True Margirt because their videos are creative and I like how their videos are edited. Here's a link so you can see what I'm talking about
http://www.youtube.com/watch?v=Ax7OKRZl5-8&feature=player_embedded.
What are some devices and programs that will help me pull off maybe 5% of what they did? Also, what are the technical terms called for some of the editng that they used in this video?
Thank You,
Newbie
Comes down to what is your source video?
What do you want to spend? And how much learning are you willing to invest?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Nothing special about that video. No tech breakthrough. Just standard pro post work.
You could build something similar with Vegas Pro but it may take you a year or more to learn how. Vegas' nested timelines make those motion splined stock footage clips fairly easy to handle.
If you are serious, first take a basic Final Cut Pro, Premiere Pro or Vegas Pro course.Recommends: Kiva.org - Loans that change lives.
Video editing software that supports importing video with multiple audio?
By elgy in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2011, 19:32 -
Webex recording changes video to side panel. Can I edit with video editing?
By Teenotes in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2011, 12:32 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Video editing programs letting you create .m2ts files with VC-1 video?
By justin0324 in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Mar 2009, 22:24 -
Which Hard Drives/setup are best for capturing video/video editing?
By Balefor in forum Capturing and VCRReplies: 4Last Post: 29th Mar 2008, 13:24
