Results 1 to 28 of 28
    Sep 2010
    Trivandrum
    HELLO to All,
    i'm using xvid4psp to hardcod subs and convert them to xvid format at same time .The resulting video is very much satisfactory but the problem is subtitle size is very small and difficult to see .Do anyone know a solution to this problem.
    Many Thanks.
  2. If you're resizing down this video before encoding, see that the SRTs are added after the resize, rather than before.
    Or (better), convert the subs to SSA format. Then you can set anything you want including the size, position, font, colors, etc.
    Sep 2010
    Trivandrum
    sorry buddy,but SSA subs are not even showing in the XVID4PSP window.got any other solutions. i will give screen shots of the video with SRT subs. how can i make the fontsize bigger????
  4. Are these SSA subs big enough for you:
    Sep 2010
    Trivandrum
    ok. are you sure this is xvid4psp version coz when i load SSA subs it is not showing up .you said that SSA SUBS can be customized.can u plz give a step by step of this process.
    Many Thanks.
  6. If they're not showing up, then customizing them won't help. How did you create them, or change them from SRT? Can you play them with a video (must have same name, like Movie.avi and Movie.ssa)? To increase the size, open in Notepad and change the FontSize (comes right after the Fontname).
    After opening the subs in the Subtitle section, go AviSynth->Edit Filtering Script and check that the TextSub line is in there. Here's what mine looks like:
    import("D:\Downloads\Encoders\XviD4PSP\dlls\AviSynth\functions\AudioFunctions.avs")
    import("D:\Downloads\Encoders\XviD4PSP\dlls\AviSynth\functions\VideoFunctions.avs")
    loadplugin("D:\Downloads\Encoders\XviD4PSP\apps\DGMPGDec\DGDecode.dll")
    loadplugin("D:\Downloads\Encoders\XviD4PSP\dlls\AviSynth\plugins\bass\bassAudio.dll")
    loadplugin("D:\Downloads\Encoders\XviD4PSP\dlls\AviSynth\plugins\VSFilter.dll")
    video = MPEG2Source("E:\Brahmachari\Song.d2v",cpu=0,info=3 )
    audio = bassAudioSource("E:\Brahmachari\Song.mp3")
    AudioDub(video, audio)
    AutoYV12()
    Crop(8, 0, -8, -0)
    Lanczos4Resize(640,480)
    TextSub("E:\Brahmachari\Song.ssa")
    I'm using XviD4PSP ver. 5.036.
  7. Member ricardouk's Avatar
    Mar 2005
    Portugal
    1- install ffdshow and enable subtitle playback with it
    2- disable subtitle in xvid4psp
    3- preview video in xvid4psp and you'll see that ffdshow will feed the sub to xvid4psp, customize size, colour etc in ffdshow and the changes will reflect on xid4psp, make sure to disable the subtitle in xvid4psp when you first load the video if you dont you'll have 2 burned subs on final video
    I love it when a plan comes together!
    Sep 2010
    Trivandrum
    ok ricardouk .i have installed ffdshow but i don't know how to enable subtitle play through ffdshow and dsable subtitle in xvid4psp .can u p;z tell me that also.
    Many Thanks.
    Sep 2010
    Trivandrum
    ok ricardouk .i have installed ffdshow but i don't know how to enable subtitle play through ffdshow and dsable subtitle in xvid4psp5 .can u plz tell me that also.
    Many Thanks.
  10. ZIP or RAR the SSA file you made and I'll have a look to see what, if anything, is wrong with them.
    Sep 2010
    Trivandrum
    hi manono,
    i converted SRT to SSA Subs using subtitle workshop and yes they are saved with the same filename but still they are not showing up .i used notepad to increase the size for SRT subs but the result is same.this is how it looks in avisynth filter when i add SSA subs.
    Sep 2010
    Trivandrum
    The SSA files you asked is posted here....................
  13. Now try:
  14. Open it in Notepad. To adjust anything, read which styles do which. The first one I've boldfaced adjusts the size and the second the height (increase to raise the subs):
    [V4 Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
    Style: Default,Tahoma,25,12632256,8026746,12632256,-2147483640,0,0,1,2,0,2,20,20,20,0,0
    Sep 2010
    Trivandrum
    Thanks Manono SSA subs have appeared in the xvid4psp window.but i want to change the font colour can u give me specifications for other colour other than white.
  16. As for colors, my suggestion is to open the SSA subs in the SubStation Alpha program and set up your styles, including colors, the way you want. It doesn't work for Windows 7 people, though. If you're on Windows 7 I'd suggest changing the extension to .ass from .ssa and opening it in Aegisub to select your colors.
    Jan 2009
    [V4 Styles]
    You can also use a similar method to resize .srt subtitle files. I always want all of my subs to be the same size and font, so I have a file called style.txt that I copy to movie.srt.style. It applies the Style formating to that srt file. You can then avoid the step of needing to convert to .ass.
    You would have the following three files when done (call out Textsub("movie.srt") like normal in your avisynth script.
    movie.mpg
    movie.srt
    movie.srt.style
    movie.srt.style would look like this:
    ScriptType: v4.00+
    PlayResX: 1280
    PlayResY: 720
    [V4+ Styles]
    Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding
    Style: Default,Tahoma,48,&H00ffffff,&H0000ffff,&H00000000,&H80000000,0,0,0,0,100,100,0,0.00,0,1,0,2,20,20,20,1
    Size of font depends on bolded number as well as the PlayResX/PlayResY numbers.
  18. He needs to set up the colors and other things to the way he wants and he'll need SubStation Alpha or Aegisub for that. It's quite difficult to do with only all that styles text to go on, especially the colors. It's easy enough to save out the styles portion of the SSA/ASS file he creates the first time and apply it to any he gets in the future. Also, zammil made a big mistake by using SubtitleWorkshop to do the conversion when SubResynch would have done it much more easily without allowing him to mess up the styles so badly so that they didn't appear in XviD4PSP. He created topsubs (is that what they're called when they appear at the top of the screen?) and his vertical height placed them well above the video so they didn't show up.
    So, I disagree about not having to convert to SSA or ASS at least once to get it set up the way you like.
    Jan 2009
    Agreed, it is easier to have one of the programs set it up once. I just meant that after that, you can use something like the .style file to have it do the same thing on each conversion so that you don't have to convert srt file to ass each time.
  20. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Originally Posted by zammil View Post
    ok ricardouk .i have installed ffdshow but i don't know how to enable subtitle play through ffdshow and dsable subtitle in xvid4psp5 .can u p;z tell me that also.
    Many Thanks.
    setup ffdshow like the above picture and disable "subtitle autoloading" in xvid4psp, while previewing the video in xvid4psp you'll see subtitles but they are rendered by ffdshow, setup the subs as you want and you'll se the changes in real time in the preview window in xvid4psp.
    from the methods everyone explained here i think this is the simplest one.
    make sure sub and video have the same name.
    Sep 2010
    Trivandrum
    ok ricardo but u still didn't tell me how to disable subtitle auto loading in xvid4psp.
  22. Member
    Sep 2010
    Trivandrum
    sorry manono to disturb u again.The SSA sub u posted worked fine. but i want to embed subs for other videos.so i would like to know how you converted the subs i posted( New WinRAR ZIP archive.zip ) to the one you posted
    FightClubFinal.zip)
    plz give step by step details so that i can use that method for hardcoding other subs.
    Thanks.
  23. Yes, it's because they're in SRT format. I've only ever seen that used with SRT format subs when they're accompanied by a separate styles file as txporter explained earlier. That is, I've never seen the styles inside of the main SRT file. I remember someone posting that was the way to do it, and if so you should ask him about it. Me, I always work with SSA.
    But that's not the styles portion of the SSA file I gave you either. txporter gave you that one.
  24. Member ricardouk's Avatar
    Mar 2005
    Portugal
    when you open a video in xvid4psp it will automatically load a sub if the sub has the same nameas the video, just deselect that sub in the subtitle menu ( i dont use xvid4psp anymore but i recall its in that menu) and let ffdshow serve the sub to xvid4psp.
    If you enable subtitle in ffdshow you'll se 2 subtitles in xvid4psp while previewing the video, if you disable the sub in xvid4psp you'll ende up with the sub that is rendered by ffdshow and then you can customize it.
    i'll install xvid4psp and post a few screenshots
  25. Member ricardouk's Avatar
    Mar 2005
    Portugal
    here it is:
    1- load video and will automatically load the sub (srt, ssa etc)
    2- click subtitle and then remove
  26. Originally Posted by zammil View Post
    plz give step by step details so that i can use that method for hardcoding other subs..
    I removed the stupid styles you created which placed the subs above and out of the picture and replaced it with my own. I already told you how to create a styles to your liking. Once you've done that save out the styles portion and apply it to your other subtitles. If the subs you get are all SRT, then create a style file as described by txporter and just reuse it. At some point you'll have to do your own experimenting and stop relying on others to do your work for you. I have no idea how you want your subs to appear. I just gave you what I like to use.
  27. Member
    Sep 2010
    Trivandrum
    Atlast i have figured it out.thanks to everyone especially manono & everyone who spent time to look into my problem.you guys don't know how much i owe you.
    Thanks.
