Hi Folks,
I have some MPEG2 files (DVD compliant) that have been converted from old VHS tapes in high bitrates with space-demanding LPCM audio, the files are too big considering their quality.
I am considering converting them to a less-demanding MB format, with means to appreciate them in a big 50” LCD TV through a media player.
Please, would you recommend a specific file format that would meet my needs ? And a software to do the conversion in batch mode ? Please, keep in mind that the quality has to be good enough for 50" TV viewing.
Also, is there a software that would convert ONLY the audio to AC3 or MPEG2 in batch mode, without touching the video ?
Thanks a lot,
Zetti
	No problem. First, you separate audio and video streams by demuxing with PGCDemux (free, here in the Tools section) or TMPGEnc's MPEG Tools. Take the PCM .wav audio file and convert it to AC3 using the WAV to AC3 Encoder (a nice GUI for Aften). Finally, remux the new AC3 audio file with the video using ImagoMPEG-Muxer. Everything here is free and easy.
  Can you make a Blu-Ray with MPEG2 format?By faramith in forum Authoring (Blu-ray)Replies: 5Last Post: 18th Jan 2011, 02:39
  Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVDBy nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15
  Conversion of DVR-MS to Standard Mpeg2 FormatBy jaffacaique in forum Video Streaming DownloadingReplies: 2Last Post: 13th Apr 2009, 05:40
  Position of subtitle & mpeg2 formatBy akakiami in forum SubtitleReplies: 9Last Post: 26th Nov 2008, 02:22
  Capturing - to what format, DV or MPEG2.?By Airjrdn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 28th May 2008, 07:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
