Greetings
OS: WinXP+SP3
DVD: LG DR389
Can I convert a dvd with only dts audio (no ac3) to dvd or any other format that can be played on a dvd player?
How to?
Your DVD should already be able to be played in a DVD player. It doesn't? Since DVDs with DTS audio are supposed to have other audio along with it, I take it you downloaded this from somewhere?
You'll have to demux the DTS audio and convert it to AC3 with some program like eac3to. Then you'll have to re-author the DVD. Yes, this can be done.
DVDs with only DTS audio violate DVD standards, so we know that this is not a commercial disc. It is possible to create such discs, but they do violate DVD standards. DVD standards state that DTS audio cannot be the only audio track on a DVD and if DTS s present, there must also be either LPCM or AC3 audio as well. -
thanks for your quick replay
manono: of course it was downloaded. "normal" DVDs come with dts+ac3. dts alone cannot be played on my dvd since I don't have dts supporting amp.
jman98: it sounds like a hard work. is it best to re-author with tmpgenc authoring works? -
Actually this guide has what is probably the "best" way to do this.
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
Just replace the DTS audio with the new AC3 audio and ignore the parts about adding new subtitles. But the workflow is the same as in the guide.
If you don't want to do it that way and are familiar with Tmpgenc Authoring Works I suppose you could use that. But you'll have to create new menus whereas the guide I linked to allow you to keep all the existing menus.
KISS me ... creating a playable on stand alone DVD player DVD
By bdaul in forum MacReplies: 7Last Post: 28th Mar 2010, 06:55 -
movies in WINAMP file want to convert to a playable DVD disk
By PBONNA in forum Authoring (DVD)Replies: 2Last Post: 3rd Feb 2009, 11:27 -
How do i convert .avi files to be playable on a dvd player?
By Beautiful Alone in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 05:03 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 02:25
