I am looking for a good router that will except or comes with a extended antenna so it will reach my shop next to my house. I guess g/n will be best.
Results 1 to 11 of 11
How far? This article summarizes ways to extend coverage.
http://www.radiolabs.com/Articles/wifi-antenna.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It is a metal building that is about 100 Ft from the router. Will these WiFi antenna work on any router?
My suggestion would be to look for a directional-type antenna (rather than omni-directional), to focus the radio waves toward your shop. Also be aware that the fact that the shop is metal may have an adverse effect on your ability to get coverage. You might want to Google "wifi metal building" or similar and see what others have come up with.
The problem with external antennas is the high cost of antenna cable. http://www.radiolabs.com/products/cables/cable.php A normal wireless n router should reach 100 feet with the supplied antenna.
The computer or network in the shop may need a separate wireless access point mounted high in the roof or external to the metal wall. You can get WAP adapters that connect USB or Ethernet. USB can run 20 ft. or so. Any wireless access point should work but these have extended range. These may be overkill for 100 ft.
http://www.radiolabs.com/products/wireless/waverv2.php
http://www.radiolabs.com/products/wireless/networking/high-power-access-point.phpRecommends: Kiva.org - Loans that change lives.
Great thanks for the info. Below is my router I have now. I would think that it would reach but my iPhone will not conect in the shop. The high power access point link... can I add this to my router now? Or does it need a router with a external antenna?
http://homesupport.cisco.com/en-us/wireless/lbc/WRT160N
Thanks -
Ok so the metal walls are my problem? I guess I should try to bring a laptop in and see if it connects. Is there any router that will work with metal walls without a repeater? My shop has no windows. I don't want to have to put a repeater in the shop if I can get away with it. What about a outside external antenna hooked to a repeater. Do iPhone's connect differently then pc's?
html fubar
You need to experiment. See if you have reception outside, then try inside.
If the goal is to put wireless connectivity (e.g. iPhone) inside the metal structure, you will need a repeater that can "see" outside and inside. If you will be using wired connections inside the metal structure (i.e a wireless to ethernet or USB), then you just need to put the antenna outside.
DLink has many wireless g and n repeaters
http://shop.ebay.com/i.html?_nkw=wir....c0.m270.l1313Recommends: Kiva.org - Loans that change lives.
see above
Router with good content filtering?
By ron spencer in forum ComputerReplies: 9Last Post: 14th Oct 2010, 20:39 -
Very good roof antenna for HDTV that is very low profile ?
By Seeker47 in forum DVB / IPTVReplies: 13Last Post: 21st Aug 2009, 02:20 -
Looking For Good DTV Antenna
By DJboutit in forum DVB / IPTVReplies: 14Last Post: 10th Jul 2009, 04:32 -
Digital antenna v analogue antenna - does it affect quality?
By Rudyard in forum DVB / IPTVReplies: 14Last Post: 13th Sep 2007, 05:51 -
Converting PAL RF tv antenna to NTSC RF antenna signal?
By SamGR in forum Newbie / General discussionsReplies: 17Last Post: 23rd May 2007, 15:05
