I have a DVD that will play on my computer but not my standalone. I converted a Real Audio/Real Video fille to several Video_TS files, I burned the largest one to disk, and it will only play on my computer not my standalone, should I have converted to something else? Please help!
Results 1 to 13 of 13
Thanks for responding Guns1inger , i have 8 Video_TS files nothing in Audio_TS i loaded them all in ImgBurn still won't play on standalone, files are as follows;
1. Video_TS.BUP 12KB
2. VIDEO_TS.VOB 430 kb
3.VTS_01_0.IFO 36KB
4.VTS_01_1.VOB 1024 MB
5.VIDEO_TS.IFO 12KB
6.VTS_01_0.BUP 36KB
7.VTS_01_0.VOB 430KB
8. VTS_01_2.VOB 21.8 MB -
How did you create this DVD structure ? Have you test played the structure from your HDD. Note : test play means using medi player classic or similar and loading the IFO file, not the VOBs.
What media are you burning to ? If it is the same as in the log you attached, it could be the cause.
When you select a Video_TS folder, Imgburn should set the file system to ISO9660 + UDF. You can confirm this before burning by checking the Options tab.Read my blog here.
#1 Why does it appear that your "source" is a DVD-R in a Lite On drive?
#2 The video in question is PAL format....you are in the U.S.? -
I did get it to play by changing the settings, but the two hour movie is not only four minutes long.
I created the DVD structure with Real Player.
The original RealMedia file is two hours long, but after I converted it and tested the IFO file as per your instructions it is only four minutes as well. What does this mean? I am using the converter "SUPER"
The media i am using is Maxell -R My friend let me borrow that same movies a year ago burned on Maxell -R
By the way my standalone is Panasonic DVD-RV27
http://www.dealtime.com/xPF-Panasonic-DVD-RV27
That was the wrong log, sorry disregard yes i am in the US. -
Wait a minute. You say your video is 2 hours long, and yet you only have a single .vob file (VTS_01_1.VOB 1024 MB) of the movie. Where are the other .vob main movie files?
Does Real Player actually create DVD-compliant files? Consider using a more reliable tool, like ConvertXtoDVD.
Maxell DVD-R is generally not the most reliable, although I don't think it is the primary cause of your current woes. Buy Verbatim discs.
So, is the source PAL or NTSC? You said you had the wrong log, but did not actually clarify which standard you had. Most US DVD players will not play PAL movies. -
Only one of the 8 files you listed is 1024 MB. You should have several if the movie is 2 hours long.
You listed your location as the US. It is an NTSC country. If your source is PAL, you're going to have a whole new set of issues. (Actually, it may be why you have problems in the first place.) Computer DVD playback software will handle it, but not your standalone player, unless it is a multi-standard unit.
If this movie is something that can be purchased domestically, the few bucks you'd spend on it will be a much better bargain than the lost time and frustrations associated with trying to fix what you currently have. -
I purchased ConverterXtoDVD not just for this task but cause I needed a good conversion program.
However it did not work with my rm file I believe my rm file is skewed at best. The VSO people claim ConverterXtoDVD can convert the rm file http://www.convertxtodvd.com-http.com/burn-rm-files-to-dvd.html
but it failed. I give up, thanks so much for your help everyone, your the best. If anyone wants a copy of the rm file pm me with your info. Until then happy converting!
MKV to AVI to play in standalone DVD player
By AzzKickr in forum Video ConversionReplies: 8Last Post: 9th Sep 2011, 13:53 -
How to create edited DVD that will play on standalone player with menus
By bahjan in forum User guidesReplies: 0Last Post: 26th Mar 2011, 14:39 -
DVD doesn't play in standalone player
By descotes in forum Newbie / General discussionsReplies: 9Last Post: 8th Jul 2009, 22:57 -
Why can I not burn DVDs that play in my standalone DVD player?
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 18th Sep 2008, 14:05 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 01:21
