I've been trying to convert some MKV videos, and when I finally found tools to properly do it, I am running into artifacting. Blocks, freezing images, etc. I've tried opening MKVs in VDubMod in the past, but I have not tried recently because I keep running into file errors.
For my first batch that I was going to use for video editing, I used SUPER Encoder, no subs. I use Sony Vegas 9 for editing.
For my second batch that is going onto my phone, I used MKV2VOB to convert to MPG (and re-transcode for hardsubbing), then Prism Video to batch convert to 256kbps MP4.
Both of them are doing the same crazy artifacting.
HOWEVER, the videos coming from MKV2VOB are crystal clear. Sony Vegas can't even load thumbnails for the AVIs I got from SUPER, but the MPGs from MKV2VOB do. [EDIT: I forgot to mention that this specific video was not re-transcoded for subs]
As for the phone videos, mine supports (or so they say) MP4 playback:
"Video playback file formats: MPEG4-SP playback 30fps VGA, MPEG4-AVC playback 30fps QVGA, WMV9 playback 30fps QVGA, MPEG4-SP playback 30 fps nHD"
I get artifacts on my phone, but not on my PC. I'm guessing this is a bitrate problem?
What exactly are you trying to achieve ? Conversion to another format for viewing ? Conversion for extensive editing ?
Vegas is not designed to edit the type of footage normally put into mkv files.
Your overall process seems to be a continual stream of re-encoding using low quality encoders and lossy compression - all of which adds up to a continual reduction in quality at every step.
While you have tried to add lots of detail to your post, the actual point of the exercise is unclear to me. What is it that you actually want to achieve ?Read my blog here.
I am trying to re-encode anime episodes that are on MKV so I can edit them for an AMV. I'm also trying to convert them so I can watch it on my phone/PMP.
Because the subs are softsubs, in addition to converting it for viewing on my phone, I'm trying to hardsub it. -
If you need to edit it then convert it to an edit friendly format - either a lossless codec such as Huffyuv or DV AVI - then edit in Vegas, outputting in the same format. Using a lossless codec will minimise or remove entirely the risk of quality loss. Xvid4PSP 5.x supports conversion to Huffyuv in an avi container.
Once you have finished editing you can do you batch conversion for the iPhone. Again, Xvid4psp supports batch conversion to iPhone and other standard devices, as well as many other formats. It also supports a wide range of subs.Read my blog here.
I tried doing a test encode to MP4 with XviD4PSP. I did add the subtitle files I extracted with MKVextract, and it showed up on the preview window. However, it did not show up on the actual video. What am I doing wrong?
What tool(s) for MP4 to MKV conversion with no reencoding?
By zdvd in forum Video ConversionReplies: 35Last Post: 17th Dec 2016, 07:38 -
MKV to MP4 without conversion
By swiego in forum Video ConversionReplies: 9Last Post: 7th Dec 2014, 11:54 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
MKV (h.264 file) conversion to AVI or MP4
By killwill169 in forum MacReplies: 43Last Post: 12th Aug 2009, 18:35 -
AppleTV - Conversion of MKV to HD MP4
By Austehn in forum Video ConversionReplies: 7Last Post: 22nd Oct 2008, 19:28
