Hi, I have an XP PC directly connected to ADSL (LAN card connected directly to ADSL modem). I have a Bluetooth USB adapter that I can plug into the PC's USB port so that my Bluetooth enabled netbook (windows 7 ultimate) can access it.
How can I safely share the PC's ADSL connection so that the netbook can connect to the net via bluetooth? Thanks.
I never heard of that.
You can share internet with Ethernet (wired or wireless) or IEEE-1394.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Apparently it is possible using Internet Connection Sharing under XP
http://www.vistax64.com/vista-networking-sharing/144354-internet-sharing-between-xp-vi...bluetooth.html
http://www.ahsan.pk/2009/06/share-internet-over-bluetooth/
However if the netbook has wireless you would be better off getting a wireless router and attaching that to your adsl modem, and then using wireless. The connection will be faster (a lot faster), more stable, and won't rely on the PC being on all when you want to connect.Read my blog here.
Yeah, a wireless router is much simpler. They're a commodity item now, you can get them for $20, or less used (Wifi "G"; Wifi "N" has higher capacity, but G already is faster than DSL Internet, so you won't see any improvement). Also they have a built in firewall. Most have four Ethernet ports for PCs as well as wifi for laptops and such.
Thanks everyone, yes I know that a WiFi router is the way to go, but right now I have this USB bluetooth and it costs nothing to try in the meantime. There are many places in the net with info on this, but none so far where I could read simple and clear instructions. I'll keep you updated if I manage to do it!
Here we go - Big settlement against sharing music on internet
By bendixG15 in forum Latest Video NewsReplies: 42Last Post: 20th Jun 2009, 21:42 -
Internet Connection Dropping Out
By Sakuya in forum ComputerReplies: 4Last Post: 28th Feb 2009, 00:12 -
Easy way to know if someone else is sharing wireless connection?
By edong in forum ComputerReplies: 5Last Post: 18th Feb 2008, 19:37 -
Help with Wireless connection and file sharing in Windows Vista
By Ollie6431 in forum ComputerReplies: 16Last Post: 10th Feb 2008, 21:52 -
Problem with internet connection
By Wizard23 in forum ComputerReplies: 5Last Post: 11th Sep 2007, 11:18
