I am desperately trying to edit xdcam files with iMovie but nothing seems to work. I downloaded XDCAM transfer which is supposed to "rewrap" the files into .mov (by the way will rewrapping allow me to edit them in iMovie?) but its telling me I dont have the right codecs and I dont know where to find those.
Please help I am about to cry for the first time in years.
Hmm, iMovie doesn't directly support XDCAM. Nor does Final Cut Express.
You need to describe the resolution, container and bit rate of your XDCAM file. There is SD XDCAM, XDCAM-HD (Blu-Ray) and XDCAM-EX (MXF wrapper)
XDCAM is very similar to HDV but allows higher bit rates and resolutions. Unlike HDV which usually transfers as an m2t transport stream, XDCAM-EX is in an MXF pro container.
Final Cut Pro has utilities to convert XDCAM-EX to AIC or ProRes422.
Best editors for native XDCAM-EX editing are Sony Vegas Pro or Premiere Pro on a Windows PC. I'm not sure of Premiere Pro on the Mac.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks so much for the detailed reply, ed.
The computer I'm using at work to edit with only has iMovie on it so does that mean I'm pretty much screwed? I tried the demo version of Calibrated{Q} XD Decode in combination with Calibrated{Q} MP4-EX Import but it leaves an unsightly watermark unless I cough up $170 to get the full version. The company I'm working for is not going to pitch in that much money for one measly video that's going to end up being 5 minutes long on their youtube channel. Is there any way I could convert the files for free or at least cheap? Thanks again for your help -
Problem wit .MOV files on iMovie
By Maurem in forum MacReplies: 5Last Post: 9th Sep 2013, 01:54 -
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 01:40 -
Can QuickTime Pro Convert XDCAM MP4 to .mov?
By boriega in forum Video ConversionReplies: 2Last Post: 15th Sep 2010, 16:17 -
export from iStopMotion to edit in iMovie 09
By kvdv in forum MacReplies: 19Last Post: 29th Sep 2009, 09:56 -
VOB to MPEG to MOV to export to iMOVIE HD 06 HELP PLEASE!
By HowardNeedsHelp in forum MacReplies: 5Last Post: 16th Aug 2009, 07:15
