Hi!
I recorded and edited a shortfilm in final cut and will deliver it to a filmfestival through their uploading system in www.imdb.com. The problem is that my shortfilm is at 2.26 GB but the maximum filesize to upload in imdb is 2 GB.
so I have to get rid of 0.26 GB by compressing it someway. The file format at the moment is:
Ive been shooting it with a Canon HV30 with this format:
how shall I do this to preserve maximum quality?Frame size:
1440x1080
Vid Rate
25 fps
Compressor
HDV1080i50
Pixel Aspect:
HD (1440x1080)
Audio format
16-bit integer
Audio Rate
48 Khz
shall I use:
- compressor?
- final cut and mixing with the export settings?
- final cut and quicktime conversion?
and in case of any above - WHICH SETTINGS?
thanks a lot !!!
Perik
Hmm, while others respond I'll ask more questions.
Is the original HDV format?
Is the project timeline AIC, ProRes422 or uncompressed? or other?
8 bit or 10 bit? ... 10 bit to 8 bit conversion wins you 20%.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Movie resolution, aspect ratio, quality, size, and compression relationship
By mario595 in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2010, 18:52 -
Lossless Video Compression for Movie Making
By Sparehead01 in forum Video ConversionReplies: 4Last Post: 6th May 2009, 18:43 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 09:17 -
Really Minor Issue
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 13th Oct 2007, 14:47 -
Best software to rip 'movie only' from dvd without compression.
By lordhutt in forum ComputerReplies: 2Last Post: 3rd Sep 2007, 19:37
