Hi there,
I'm seem to have an odd issue playing the AVCHD structure from an external harddrive (2 TB). The video is approximately an hour and half long and so it is split into 3 chunks to accommodate FAT32 and this is done automatically when choosing the PS3 output in multiAVCHD, profile is of course is 4.1. After it's complete I copied the film onto root of my external and the folder renamed to AVCHD. The film plays perfectly with chapters, multiple streams etc. but then suddenly at random, the picture will freeze, the green light on PS3 blinks erratically and I'm taken back to PS3's menu dock. After I try playing the film again it will start from the beginning and I can chapter right before the freezing point and it will continue correctly for the duration. This random stop only happens once but always at a different spot usually around 30-40 min in. Has anyone else experienced this problem and can offer possible solutions? The PS3 is updated to its latest firmware.
I also tried taking the m2ts file and splitting it just using the Tsmuxer with the AVCHD disk checked. Unlike the multiAVCHD method this yields the additional CERTIFICATE folder. Again, I copy those into a AVCHD folder that is in root of the drive and I use the AVCHDme to make it 8.3 playback compliant. But unfortunately the same problem will occur, with the video freezing at a random point and I'm kicked out into PS3 menu dock.
Question, is special treatment required when multiple videos are on the same drive? Thus far I've been simply renaming folders depending on what I'm gonna watch. The video I'm about to watch I will rename into AVCHD and then back to its title once I'm done. Then rename the next one to AVCHD and so on etc. Is this a correct way of doing it?
I would really appreciate some of your thoughts with this issue, it's starting to become a bit frustrating.
Thanks,
Tom
http://www.tdimension.ca
hi, did you ever find a solution to this problem....I am having the same issue....much appreciated
My PS3 plays my AVCHD video well.
By jbitakis in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Jan 2012, 13:04 -
AVCHD playback problems on PS3, black screen at midway point
By mikeveli20 in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Mar 2011, 12:46 -
AVCHD DVD playback on PS3 failed
By joe4yoshimi in forum Video ConversionReplies: 1Last Post: 29th Dec 2010, 21:54 -
AVCHD DVD and PS3
By DesossiriboNucleicAcid in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Feb 2010, 14:14 -
AVCHD burned stops half-way through
By misfitzx138 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Jan 2009, 17:27
