  1. Hi,
    I'm using SpruceIt to try to make a DVD menu. I have a large MPEG-2 file (2.13 Gbs) that is in the correct format (thanks to TMPGEnc) and plays back faultlessly. The trouble is, when I try to import it in SpruceIt, it gets to 6% and dies!!! Any help? i've tried it in 98, XP and ME, with FAT32 and NTFS!! Please help!
    PnaG.
    you mean spruceUP or dvdIT? if you using spruce up you could demultiplex the mpg and try import it(the audio will automatically be added) www.vcdhelp.com/faq.htm#demultiplex
  3. I'm using SpruceUp, sorry! I'll give de-multiplexing a go. Thanks!
