I am trying to play the new MMO Final Fantasy XIV which comes out later this month. That game requires a lot of processing power to play, much more than any of my current computers.
I figure I might as well just start over and build one from the ground up. My brother recently bought a 3.2ghz quad core, 1GB video card, 4gb ram, 600 GB HDD comp for about $600, and that included the case. Still I know it all starts with the MOBO but I don't really know which one I should get. The computer needs to be comparable to my brothers because even his comp barely passed the benchmark for the video game.
My budget is around $600. I already have a 256mb video card but its about 3 years old. I also have year old ram. Thanks! Any suggestions are very appreciated!
Results 1 to 11 of 11
case - $40
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
power supply - $40 (after rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
processor - $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103706
dvd burner/rom - $24
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
hard drive - $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
RAM - $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231275
Motherboard - $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157198
Video Card - $125 (After Rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
Total Cost - $550
this setup should easily get you what you want...and for less than $600 -
that raidmax ps is not the greatest....a power supply is the most important part of a pc...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
Gigabyte is a better brand of a motherboard.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444
Just my 2 cents! -
I'm just curious, what is the significant different between the
http://www.newegg.com/Product/Produc...82E16813128444
and
http://www.newegg.com/Product/Produc...82E16813157198
I see the 20 dollar price difference but I don't really know enough about computers to understand the processing difference. Can anybody explain? -
one has built in on-board video and is made by a good company, the other no video and is an asus budget line product.
Do I want built in, on board video? I know I'm buying a 1GB video card, so is build in video necessary?
Maybe not right now, but on your next upgrade you could put together a cheap box and sell it, the other mobo you would have to throw in a video card.
I also prefer Gigabyte boards. -
I want a video card. I'm going to need a good one to run this game. It's not a normal video game. Requires an insane amount of processing power. My brothers computer I described above only got an average score on the games benchmark test.
So why the question about on-board video? You'll just not use it, and use the video card instead. On-board video becomes a non-issue when deciding on a motherboard; you'd focus on the other specs of the M/B and make your choice.
Unless you have an extra video card with a compatible interface sitting in your spare-parts bin, onboard video is good to have as a backup in the event your primary video card has a problem.
Building a new computer and need some advice.
By ingeborgdot in forum Media Center PC / MediaCentersReplies: 79Last Post: 11th Dec 2011, 12:00 -
Need advice on Computer with AGP slot
By TaranScorp in forum ComputerReplies: 32Last Post: 9th Aug 2009, 12:50 -
Computer upgrade Advice...
By helper in forum ComputerReplies: 24Last Post: 31st Jul 2009, 12:13 -
Advice on new Computer Purchase
By wiseant in forum ComputerReplies: 12Last Post: 17th May 2008, 03:56 -
Advice on online computer deal?
By Super Warrior in forum Off topicReplies: 4Last Post: 13th Jan 2008, 00:18
