I am having problems setting the custom resolution on my graphics card to 1366x768 60Hz which is the one suggested by the manufacturer of the HDTV I am using. I have plugged in a DVI to HDMI cable. At the moment I gave been using the closest resolution which is 1368x768, though this gives a poor quality image ie. the text is nearly unreadable when small, and images look like slightly posterized:
http://communities.intel.com/servlet/JiveServlet/showImage/2-100267-21366/Pic1.jpg
I have contacted Ebuyer.com, seller/manufacturer of the Foehn & Hirst TV and they have offered no help. Using the custom resolution settings in the Intel control panel I can select a resolution of 1366x768 but only 30Hz is available which makes the display like this:
http://communities.intel.com/servlet/JiveServlet/showImage/2-100267-21372/Pic2.jpg
Does anyone know of any solutions to this problem other than buying another, better TV?
I changed the images to just links or it would be hard to read this thread.
It's called 1:1 pixel mapping when you try to get same resolution as the hdtv. See http://pixelmapping.wikispaces.com/Pixel+mapping+explained .
But I don't think you will be able to get 1366x768 perfect with your card....I can't get it with my ati card...
Cheers, I couldn't work the image attachments out.
Thanks for the quick response. I have read into pixel mapping and tried to use Powerstrip software to sort the problem but had no luck.
Would you recommend I considering buying different HDTV that doesn't overscan? Although not many manufacturers stipulate whether it happens or not....
I have had the PC through a 50" Pioneer TV and the picture quality was perfect without me having to change any settings!
Matt -
Yes, the problem is that your TV takes the incoming image, resizes it to about 1428x806, then shows the middle 1360x768 portion (simulating overscan). Digital resizing results in artifacts like you are seeing. (With 30 Hz output I think your computer was putting out an interlaced signal and the TV was deinterlacing resulting in even worse quality.) If you switch to VGA your HDTV probbably won't overscan since it knows that comes from a computer where you need to see the entire image.
If VGA doesn't help, you can't convince your HDTV not to overscan, and you need to read small text on the TV, you'll need to get a TV that doesn't overscan. Most Samsung and Sony 1080p LCDs have non-overscan options. -
On my Samsung the non-overscan mode is called "Just Scan". You get it by pressing the button on the remote that cycles between 4:3, 16:9, Zoom, Just Scan, etc. I don't remember what Sony calls it. Some call it pixel-for-pixel, or 1:1 pixel mapping, etc.
Problem with custom DVD subtitle
By amontagner in forum SubtitleReplies: 3Last Post: 26th Mar 2012, 21:38 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 14:14 -
Converting Avi To MP4 Ipod with custom resolution
By zander20 in forum Video ConversionReplies: 2Last Post: 28th Nov 2008, 13:59 -
Force custom resolution for TV out in CLONE mode for DV Capture ?
By TheParadoX in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 19:00 -
HD TV Resolution Problem
By jemoto in forum DVB / IPTVReplies: 9Last Post: 29th Mar 2008, 04:45
