I've the following problem.
I own a samsung omnia hd mobile, capable of recording hd videos at 720p.
When i try to play on my ps3 the produced files, it gives me an error "unsupported file type".
But if i try to play files recorded at 720x480 it works flawlessly.
So i throwed both of them to Gspot, and the only difference i can see between the two files is fps:
24 fps for 1280x720 videos, 30 fps for 720x480 videos.
Since I DON'T WANT TO REENCODE VIDEOS, is there a way to change the fps header and set it at 30 so i can give it a try?
Or otherwise is there some software to transcode it and make it ps3 compatible (i tried mkv2vob but didn't work)?
Thanx in advance.
24fps should work fine.
Try multiavchd and make a avhcd m2ts files that might work better. Or else reconvert with handbrake, choose the ps3 profile and convert. Or stream with PS3 Media Server.
How to change 30 fps to 29.97 fps ?
By pchan in forum Video ConversionReplies: 5Last Post: 9th Feb 2012, 18:57 -
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 14:09 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 06:37 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
