    Sep 2010
    Australia
    I have just installed vob2mpg so I can access a vob file as mpg to use in Pinnacle Studio 14. I am runnning win7 with an i7, 8 gig ram. I had no trouble installing vob2mpg and apparently no problem converting the vob except the mpg image is elongated vertically - everyone looks tall and skinny whether viewed through Media Centre or Pinnacle. Any suggestions please?
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    The file is fine.
    See https://www.videohelp.com/glossary?A#Anamorphic
    You can probably get it to look normal in your editor if you look for settings related to "Aspect ratio".
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Sep 2010
    Australia
    Thanks guys, I used Any Video Converter [free version] and changed the aspect to 16:9.
    {I'm not sure how to finalise this thread though}
