Hi everyone,
I'm very new to video conversion etc.. I did see that there were some posts on this before but I'm not sure how to implement coding lines.
I'm converting an mp4 into xvid, the picture quality is fantastic but I can't get any sound output.
I'd really appreciate any help, I need to finish a project in the next 36 hours and I'm panacking.
Thanks in advance
Mark
Hi Socrates,
Many thanks for your reply. I'm not bothered about getting 5.1 audio, I don't mind if its in mp3 or any other format I just can't get it it output any sound on the convertor.
Any ideas how I could do it on ffmpegx ?
Thanks again
I'm new to this video- audio authoring. I haven't yet used ffmpegx but if you are not bothered about 5.1 changing to mp3 stereo, then the available free softwares that could help you are- Super, Xvid4PSP and Avidemux. The fastest I guess is Xvid4PSP. All have guides available to help you out. Try any of them out...
In ffmpegX, try converting using the "XviD ffmpeg" preset.
If it errors with a 0 KB output file, try again with "invert mapping" checked in the Audio tab. That is the solution to the most common cause of 0 KB output when using ffmpeg presets.
When asking for conversion help with ffmpegX, please be detailed about your input file. What does the Summary say about your source file (video codec, resolution, audio codec, sampling rate, number of channels)?
If the conversion fails or the output is lacking something, please also provide the content of the Process Information log. You may access this by clicking the blue "i" in the ffmpegX Progress window after a conversion attempt.
That output should give fellow forum users a good clue about what exactly happened.
Please help me about converting avi (xvid) to MP4 (Ipod touch 4g)
By jolo in forum Video ConversionReplies: 2Last Post: 4th Jul 2011, 03:38 -
Urgent Help needed: all video converters corrupt my mp4 files, accelerating
By marilia05 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2011, 06:50 -
Converting Videos with a Time Delay to XviD/MP4/MKV?
By BNA84 in forum Video ConversionReplies: 4Last Post: 5th Feb 2010, 18:20 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51 -
Having Problems converting h.264 mp4 to xvid using avisynth & vdubmod
By Rusty Shackleford in forum Video ConversionReplies: 3Last Post: 8th May 2007, 04:34
