    Jun 2007
    Kuwait
    Hi,
    Have a sound file was filtered in Audacity used Noise Removal and Equalization filter but there is some part of the sound has low volume and the other has high volume. Is there a filter can fix this problem ?
    Sample file:
    http://www.mediafire.com/download.php?0fkx4hrz7d5pfth
    Best Regards,
    SB4
  2. That's best done by manually riding the pot. But try the Compressor filter with a lowish threshold (~35) and a moderate ratio (~3:1).
    Jun 2007
    Kuwait
    thanks jagabo,
    It is look like better
