I have a full DVD-9 project, usually set Encore CS3 to auto setting for encoding. When I set it to auto, in the build screen it says 8.54GB used, and 4.288MB free. The problem is that I have about 33MB of ROM content to add. I used to add the ROM folder in GPME, but I'm afraid if I do that, it will be too big. Should I just add the ROM content in Encore? Or should I change the bitrate encoding to allow for enough space to add the ROM content later?
Results 1 to 1 of 1
How do you use Adobe Encore CS3?
By Banleno007 in forum Authoring (DVD)Replies: 2Last Post: 20th Feb 2012, 11:33 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Exporting from Premiere CS3 on PC to use in Encore CS3 on Mac
By meltait in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2008, 14:15 -
By zanos in forum Authoring (DVD)Replies: 0Last Post: 24th Apr 2008, 21:04 -
Encore CS3 Libraries
By vin4evr in forum Authoring (DVD)Replies: 0Last Post: 20th Feb 2008, 10:46
