Anyone using alternative software for Easycap model DC60 , bundled (Ulead Studio 10). If anyone uses or can recommend software to use with this device in combination with capture using Win Movie Maker. I have had problems with file size using Ulead software. Anyone who can create dvd from VHS VCR TV recordings with this device instructions welcomed. Cheers BTW the VCR recordings are european system.
visionman
Health IS the first Wealth------So do not strain your eyes!
What sort of problems ?
Ulead Studio 10 has a dvd template. I think it is set at default for 8,000 kbps. That means one hour of recording per disk. Need more ? Just reduce the data rate = 4,000 for two hours. -
Thanks DB83, did not know that, thanks. Problem, was lack of clear instructions with this device,regarding setting up the thing. Checked out setup on You Tube. Thanks again, DB83 for your help. Cheers
visionmanHealth IS the first Wealth------So do not strain your eyes!
easycap capture card
By Howieb123 in forum Video Streaming DownloadingReplies: 8Last Post: 28th Mar 2011, 11:48 -
capture tool for easycap
By liran054 in forum Capturing and VCRReplies: 2Last Post: 2nd Mar 2011, 12:32 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
EasyCAP DC60 capture help
By dtreacy in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:40 -
EasyCap capture card
By VirTu3 in forum Capturing and VCRReplies: 0Last Post: 5th Dec 2008, 18:56
