I filmed a live 30 minute radio broadcast, which has live callers calling in. The xlr cable is comming out of the mackie and into the jvc camera. The aduio was overmodulated. Is there a way I can fix it,, so the callers don't sound so muffled? The video editing software I use is "Sony vegas movie studio 9 platinum" thank you?
You could try a high pass filter on the audio and kill some of the low frequencies and see it that helps. I don't know Vegas's audio capabilities, but you could also try the freeware audio editor Audacity and see if you can get some improvement there. With audio filtering, less is usually better. Sometimes you can make improvements, sometimes not.
Others here may have some better advice. If you could post a short representative audio clip, preferably in the native audio format, maybe ten seconds or so, you may get more help that way.
And welcome to our forums.
Attempting to create DVD from Sony Vegas Movie Studio 9 Platinum...
By Greg / MO in forum Authoring (DVD)Replies: 6Last Post: 7th Aug 2013, 12:37 -
Video Artefact Problem - Sony vegas Movie Studio Platinum 9
By abeelandig in forum Video ConversionReplies: 5Last Post: 11th Jun 2011, 10:40 -
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 18:33 -
Is Sony Vegas Movie Studio HD Platinum 10 a good editing software?
By vid83 in forum EditingReplies: 8Last Post: 4th Feb 2011, 07:02 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 22:38
